92 Acura RS to GS Swap
Old May 10, 2003 | 02:59 PM
Phantisy's Avatar
Phantisy
Default 92 Acura RS to GS Swap
I own a 1992 Acura Integra RS Hatchback and I wanna put an engine from a 1992 Acura Integra GS 4 door. What would I need to do this other then the engine (DUH!!)... Or can I just drop the new on in as is?????
Old May 10, 2003 | 05:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
They're the same exact engine.
Old May 10, 2003 | 05:33 PM
Phantisy's Avatar
Phantisy
Thanks. I seen on a few sites that that 92 RS had a B18A and a 92 GS had a B18B.
Old May 10, 2003 | 05:48 PM
qtiger's Avatar
qtiger
Lies!
B18b is just a later model of the B18A, not an optional version.
Old May 10, 2003 | 05:52 PM
Phantisy's Avatar
Phantisy
figures that would be the case. At least I know it will be a clean swap. I am putting the new/used engine in cuz it runs alot better then the one I have now and then I am going to rip up and rebuild the old one with high performance and make it a new one
Old May 10, 2003 | 10:27 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Just look at the new block, if it says B18B on it, then that's what it is. The only difference is that one is newer. The B18B has a hydro tranny, and the B18A has a cable one. If you have a B18A right now, you'll need to retain your tranny and use it with the B18B.
Old May 11, 2003 | 06:16 PM
Phantisy's Avatar
Phantisy
What dose "retain your tranny" mean? And what is the differance between a cable tranny and a hydro tranny?
Old May 12, 2003 | 07:28 AM
Redcivic's Avatar
Redcivic
One of the original OG's
When you say runs a lot better what do you mean? Try a tune up.
Old May 12, 2003 | 08:50 AM
Phantisy's Avatar
Phantisy
A tune up wont help the engine I have. When it starts it rumbles and has a light knock. The new one/used one runs very quiet and smooth.
Old May 12, 2003 | 12:28 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If the swap engine uses a different tranny type from the engine in the car, keep the original tranny and mate it to the new engine. A cable tranny really refers to the clutch type - where the clutch engagement is controlled by a cable, rather than hydraulic pressure from a clutch master cylinder.
