starting problem
Old Jun 10, 2003 | 08:24 AM
South_Paw757's Avatar
South_Paw757
Default starting problem
Has anyone had this problem.
My 92 prelude SI usually runs great but every now and then it will crank but not start. I checked it for spark and it looks good but the car still doesn't start. If I let the car sit for anywhere from 5 minutes to an hour, it will start up without a problem.
Does this sound familiar to any of you good people?
Thanks,
Wesley
Old Jun 10, 2003 | 08:59 AM
crxb16er's Avatar
crxb16er
its gonna either be spark, fuel, or air related, first thing to check is ur spark plugs, cap and rotor, and spark plug wires, then u may want to check ur fuel injectors, and fuel filter, then check ur air filter make sure that isnt clogged or disgusting, do u notice any loss of power while driving or is it just during start up? could also be that ur battery is discharged or bad. whens the last time u did a full tune up?
Old Jun 10, 2003 | 12:35 PM
JimBlake's Avatar
JimBlake
Sounds like the main relay, it's a common problem with Hondas. Listen for the fuel pump to prime, it's not real loud, but it should run for 2 seconds when you turn the key on.
Air filter has to be really bad to prevent starting. It'll run real bad at high rpm & high load, but idling doesn't pull much air thru. To lose air you almost have to stuff a softball in your intake pipe.
Old Jun 10, 2003 | 12:45 PM
crxb16er's Avatar
crxb16er
yah its hard to kill the car once its on but during start up if its kinda clogged it can cause u to crank it a bit b4 it kicks over by itself.
