general turbo question
Old Jun 3, 2003 | 03:05 PM
crucial v.2.2's Avatar
crucial v.2.2
Banned
Default general turbo question
when i rev the motor in neutral, it goes into boost, and never did before today
why?
and when i take the filter off the turbo, the BOV gets extremely louder
why?
Old Jun 3, 2003 | 03:08 PM
DakarM's Avatar
DakarM
umm usually you don't get much boost even revving to redline in neutral because there is no load.
and
because it's sucking up a lot more air? :dunno:
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Jun 3, 2003 | 03:10 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Shouldn't boost without load usually....sounds like somethings wrong.
And Rick got the second on the head
Old Jun 3, 2003 | 03:12 PM
DakarM's Avatar
DakarM
Originally posted by crucial v.2.2
rick, it goes into boost, 5-6psi if i rev it up..even with no load
like John said that is not good.
not good at all. time to post this on the engine tech and see if Inspy can help you out
LCD Squad #0001
Old Jun 3, 2003 | 03:13 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
thanks for being a noob.
and rick, it goes into boost, 5-6psi if i rev it up..even with no load
JFWY anyways but yea post up in engine tech or I could ship this thread that way if you want.
Old Jun 3, 2003 | 03:14 PM
crucial v.2.2
Banned
it started today, and im boosting more 7psi..before was only at 5 and stayed there...i fixed all my vacuum leaks, and now thats what im getting now (first post)
crucial v.2.2
Banned
can you copy it over?
Old Jun 3, 2003 | 03:15 PM
dubcac's Avatar
dubcac
I
It will go into boost in neutral if you are into the throttle enough.
Old Jun 3, 2003 | 03:38 PM
crxb16er's Avatar
crxb16er
ur turbo is dependant on the exhaust gases reving it up, so ur gonna get boost if u just rev on the engine in neutral and there is enough exhaust going thru the turbo to wind it up enough, but you should not get near as much as if u had a full load during normal acceleration at the same higher rpm, how many lbs of boost are u normally pushing? and does it only push alot of boost when ur reving in neutral at high rpms?, do u have a really small turbo that kicks in at early rpms? you could just stop reving it up into high rpms when u dont want power, may be functioning normally.
Old Jun 4, 2003 | 05:04 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
What kind of wastegate are you using?
-Harry
AIM: NDcissive
