going very leasn in LS/VTEC - help needed
Old Jun 12, 2003 | 01:00 PM
WojtekG's Avatar
WojtekG
Default going very leasn in LS/VTEC - help needed
My LS/Vtec coversion runs so lean I'm afraid of driving it and can not find problem that causes such A/F ratio.
My setup is
B18B block
B16A head
P30 ECU
B16A Intake manifold
I wonder if someone could give me sum clues what can I do to increase A/F reachness. Can it be problem with ECU, so I hould use 1,8 VTEC ECU?
Old Jun 17, 2003 | 03:55 PM
Trance303's Avatar
Trance303
You can try.
1. larger fuel pump and adjustable fuel pressure regulator.
2. ecu may need to be tuned with somthing like hondata to change fule map
3. A'PEXi fuel timing controller (excelent v tec fule maps.)
