questions about turboxs boost controller
Old May 16, 2003 | 10:18 PM
yokogsr's Avatar
yokogsr
Default questions about turboxs boost controller
hey guys, i just installed turboxs high performance boost controller. the problem is: i can't adjust the controller! maybe i didn't hook it up correctly? what's the right way to hook it up with my turbonetic deltagate? the wastegate has 7psi spring. can i adjust the boost greater than 7 psi? or 7psi is the limit?
Old May 18, 2003 | 11:52 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
A boost contoller can only raise boost above the level of the springer, it can never lower it. How are your vacuum lines run?
