Replacement for D16y7 header
Old May 15, 2003 | 05:33 AM
DRTHV8R's Avatar
DRTHV8R
Default Replacement for D16y7 header
I'm working onmy buddies '96 4dr lx civic, and it has a crack in the header. It goes from the O2 sensor toward to block. My real question is the cat converter seems to be part of the exhaust manifold, is there a performance header I can put on, or will I have to add a cat converter down stream if I put a 4-2-1 header?
Old May 15, 2003 | 06:50 AM
v4lu3s's Avatar
v4lu3s
you ahve to add a cat if you get a header.
Old May 15, 2003 | 11:24 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You need an EX cat and either cut your existing midpipe, or run an EX exhaust.
