Compression in LS/VTEC: 11.6:1?
Old May 10, 2003 | 12:24 AM
WojtekG's Avatar
WojtekG
Default Compression in LS/VTEC: 11.6:1?
I just calculated compression ratio in LS/VTEC I'm bulding. I used c-speedracing on-line calculatior. The result was 11.6:1, when I used B16A with B18A and pistons from B16A USDM.
My question is: Is this compression too high for this engine to make reliable or I don't have to worry about it t all? Are there any necessary additional upgrades to the hybrid engine I shoud make to be secured with such compression?
Old May 28, 2003 | 05:34 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Im not sure about the ls block's ability to hold up to high compression, but im sure if they can hold all that boost people throw at it im sure it will be fine. Im running 11.6:1 compression, and have had no problems, just keep the higher octane fuel in there:thumbup:
Old May 28, 2003 | 07:02 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
What kind of octane do you guys get over there in Poland?
Old May 28, 2003 | 10:39 PM
WojtekG's Avatar
WojtekG
We have 95 (normal) and 98 (super), but I think the real octane ratio is 2 points lower.
Old May 29, 2003 | 11:33 AM
likaciv's Avatar
likaciv
nice
Old May 29, 2003 | 12:25 PM
brtecson's Avatar
brtecson
pukimonster
guys, keep in mind that there are two different ways of rating octane
Old May 29, 2003 | 02:29 PM
qtiger's Avatar
qtiger
That compression is fine for a daily driver using US premium gas.
It usually isn't a concern until you get over 12:1, and then you just have to be a little more careful.
Old Jun 25, 2003 | 08:03 AM
racinategra's Avatar
racinategra
11.6 to 1 is what you are yielding from that. So approx my ls/vtec should be running 11.8:1 with b18a block b18c head and civic type r pistons? I heard with the GSR head you add .2 to the compression yielded from a b16 head. Thanks.
Old Jul 23, 2003 | 12:46 AM
Civic2Scooby's Avatar
Civic2Scooby
if you have that exact setup you are pushin more like 12.3:1
Old Aug 14, 2003 | 05:02 AM
ultra_ferio's Avatar
ultra_ferio
i have a b18b block w/gsr head. my cr is 12.8:1 using 100 octane. if the motor is built right, should be reliable. my motor is also daily driven too.
