OBD1/ OBD2 02 sensor locations.
Old May 27, 2003 | 09:42 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Default OBD1/ OBD2 02 sensor locations.
I needed to replace my a-pipe (lower-portion of my header, the collector portion). And the one I got doesn't have an 02 bung, but it is reportedly from an 1998(obd2) car.
For a better visual, it is missing one, before the cat.
Is this an obd2 a-pipe, or have I been misled.
I was under the impression that all obd2 setups had two 02 sensors, one before the cat, and one after.
Luckily, my ecu is obd1
-PHiZ
Old May 28, 2003 | 04:31 AM
drift's Avatar
drift
Flaccid Member
OBD II has 2 O2 sensors as you describe. you've been bamboozled with that replacement A-pipe.
if you're OBD I converted, you still need the forward sensor... it's the only one that will give you accurate readings for the fuel mixture.
Old May 28, 2003 | 05:45 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If it's a D series, the secondary O2 goes on the cat itself, not on the manifold. So you'd have one where they all go on obd1 cars (on the upper half of the manifold), and another on the cat.
Old May 28, 2003 | 06:22 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Hrm, right now it's running with an obd2 sensor setup on an obd1 ecu. With one 02 sensor immediately beofre cat, and one immediately after.
If the obd1 02 sensor location is higher up on the manifold, I believe that makes it a 1-wire 02 sensor, i.e. an 02 sensor without a heating element. Hence the placment near the manifold to heat it up.
So I guess I need to: tap an 02 bung in the a-pipe/collector, and then make sure I am using an ecu that can control the heated sensor. I am using a p28 currently.
-PHiZ
Old May 29, 2003 | 11:46 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I have a 97 Civic. My stock manifold had the primary heated O2 on the #3 runner. Placement of the O2 doesn't necessarilly correlate to it being heated or non-heated. OBD-I cars for the most part use 4-wire heated O2's. The only cars that I have seen non-heated O2's on were non-OBD, or OBD-0. Your P28 will have no problems running a 4-wire heated O2, unless it's been modified to run a single-wire O2.
Old May 29, 2003 | 12:53 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Yeah, this is so weird. I have a 99, same generation as you. And my stock 02 locations are before and after the cat. Nothing on any of the exhaust primaries.
So inspyral, if your "forward" 02 sensor location is on the primaries, I'm guessing you don't have any on the collector. And I do have an obd2 a-pipe.
so let's see what we got:
your car: 97
donor car: 98
my car: 99
I wonder if the 02 sensor location correlate to OBD2a vs. OBD2b ???
nope
OBDII A (96-97) and OBDII B (98-00) connectors.
WTH
Also, I have it on good authority that the p05 ecu uses 1 wire 02
So, what would be easier, cutting the good flange off the non-bung pipe, and welding it on to my existing a-pipe w/bung.
or
Drill-pressing a hole in the non-bung a-pipe, and welding a bung? Anyone got the specifications of the bung on-hand?
-PHiZ
Old May 29, 2003 | 05:05 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I just got out from under a friends 98 civic ex, 4 door. She has the configuration with the forward 02 on the exhaust runner/primaries...
-PHiZ
Old May 30, 2003 | 11:05 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
96-98 is OBD-IIa, 99-00 is OBD-IIb
If you need to have an O2 bung added, it should only take about 5 minutes at a muffler shop. They'll have the bung there, or you can order one from Summit for about $5.
Old Jun 1, 2003 | 08:10 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Hondata website seems to disagree with you...
I dunno, I respect both of your opinions so much, I can't decide...
I just asked the guy that sources my ECUs and harnesses, and he pointed me to this chart he did up, reposted here with his permission.
apparently you have to take into account the year of car, but also model...
http://www.crimethink.org/images/obd2_years.html
-PHiZ
Old Jun 2, 2003 | 10:25 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I assumed you were talking about Civics, in which case, what I said stands.
