compatable tranny
Old Jun 6, 2003 | 03:27 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
Default compatable tranny
i have a '97 ex 5 speed coupe. my tranny's going finally cause im at about 85k miles and i've abused the car so much. im turbo'd and running 10lbs, so i have a decent amount of torque. any suggestions on campatable trannies or which one would work best gear ratio wise? i just dont wanna get whored into buying another stock rebuilt one from the dealer or even from my mechanic for a grand or two. thanks....
Old Jun 6, 2003 | 08:40 AM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
well...if you are making a decent amount of power...you could try an lx tranny...the gears are hella long and if you have the nuts for it could be really quick... 1st=40, 2nd=65, 3rd=100, 4th=limiter
something to think about
Old Jun 6, 2003 | 09:34 AM
qtiger's Avatar
qtiger
Any D series transmission will work. The EX has the highest ratios, which is typically what you want to stick with unless you can't keep traction. Or you have a stump puller 1st.
Also, I have an EX tranny for sale if you are interested.
Old Jun 6, 2003 | 10:04 PM
silverstreakin
TRD japan ownerages
how much??
Old Jun 7, 2003 | 01:29 AM
yellow civic ex
yea, i would be very interested...how much are you asking?? how many miles?? anything need to be replaced on it?? where you live?
Old Jun 7, 2003 | 01:35 AM
yellow civic ex
im running about 180whp and about the same torque @~5500rpm. decent for a civ. prolly wanna stick with the ex tranny anyways.
Old Jun 7, 2003 | 02:26 AM
silverstreakin
TRD japan ownerages
WOW 180 torque??? what cams????? good lord man....a honda engine with that kinda torque and its a d series? whats your secret...
Old Jun 7, 2003 | 02:27 AM
silverstreakin
TRD japan ownerages
that kind of torque for real...lx
Old Jun 8, 2003 | 02:03 AM
yellow civic ex
it's just a small 15g turbo w/ fmic and some other stuff tuned up a lot w/ a port+polish. stock cams tho for now. i was impressed, since people like jkan from HAN has a better turbo than me, but was dyno'd at less. it's prolly cause im running more boost or something. i wanna get the new tranny in and switch my new clutch over and try my hand in the 1/4 mile. with much luck and a good launch im hoping for the very high 13's. maybe i'll just get the ex cause i know ill like it anyways. in high gears is the lx stronger??? for example: if i wanted to top out my car and redline @ 7k in top gear (maybe someday) would it be faster????
Old Jun 8, 2003 | 02:27 AM
silverstreakin
TRD japan ownerages
i would think so...i know the lx gears are longer than the ex gears...100 in 3rd at 7000 fourth gear hardly pulls its so high...with the power to back up those gears....you would have monster high speed (better get those z rated tires )
and first gear is still low enough to give you hella acceleration
