Originally posted by yellow civic ex im running about 180whp and about the same torque @~5500rpm. decent for a civ. prolly wanna stick with the ex tranny anyways.
Any d series tranny will work. I believe that any b series gears will fit into the tranny. So you could buy a b series tranny and switch the gears to yours.
I have two, actually. The second one's been exposed to air for a year, so the input shaft and starter shaft are a little rusted. The starter I'd pick up at a junkyard, but the input shaft could be cleaned up with a little bit of patience.
Originally posted by yellow civic ex yea, i would be very interested...how much are you asking?? how many miles?? anything need to be replaced on it?? where you live?
Asking for reasonable offers. Miles are unknown, but the two were pulled out of 99 and 00 Civic EXs a year ago, so I'm estimating 50,000 miles or less.
I was told both are in good condition. The good one is attached to a spun bearing motor, the slightly rusty one was used by someone who got a little too nitrous happy and threw a rod through the block.
I'm in southeast Michigan. Zip is 48189 if you want to Mapquest it or something.
