oil pump
Old Sep 13, 2002 | 06:36 AM
maxrpm's Avatar
maxrpm
Default oil pump
I have a ls/vtec and the oil pump is a ls. The problem is my vtec is not working. IT will try to change over but you will feel a lag in the car as it hits the vtec range. I checked the vtec oil pressure and it reads 50psi 10 below the normal. Do i need a gsr oil pump and whats the differences between them?
Old Sep 13, 2002 | 12:57 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
the vtec oil pumps and the b20 oil pumps are a bit higher, but it shouldn't make a difference. This happened to a friend of mine. Double check your timing (cam and ignition), and if its not off, take your cat off and drive it around like that, and check to see if you can see through it, if not, smash the internals out (or buy a new one). Its cause when it goes into vtec it gets choked off by the ****ty old cat. At least, thats what happened to my friend....
Old Sep 13, 2002 | 01:25 PM
maxrpm's Avatar
maxrpm
was your friend using the b18 or b20/b18c1 oil pump? I 'll try that and see if it works this weekend. the timing and everything is correct.
Old Sep 13, 2002 | 01:32 PM
dubcac's Avatar
dubcac
I
You need to use a vtec oil pump, the LS doesn't have enough pressure to engage vtec. You can modify the LS pump to flow higher by shimming the spring, but I don't really know how much to shim.
Old Sep 13, 2002 | 03:17 PM
maxrpm's Avatar
maxrpm
What do you mean by shimming the spring ?
Old Sep 14, 2002 | 02:23 PM
maxrpm's Avatar
maxrpm
My vtec works now but i don't real feel any hard pull. It doesn't seem to lag when i hit the vtec range. The problem was my cat was clogging up the exhust gas from flowing through.
chinahanji
Vehicle Classifieds
Jun 9, 2006 09:32 PM
GTKage
Dec 31, 2002 05:24 AM
erniecars
Sep 17, 2002 03:04 PM
