Idle Problem, someone please help
Old Sep 12, 2002 | 06:42 PM
chuckd05's Avatar
chuckd05
Default Idle Problem, someone please help
I have just wend through a whole engine rebuild, my motor was pulled and put back in, and every since i first installed cams on my car my idle was ****ty, everyone told me it was my 6403 crower cams and it will go away if they were taken out. I had valve springs and retainers put in as well at the time. Well i went away from all motor than i went turbo so i took the cams out and the idle is still bad. A year later, still bad. It is not the IACV that was changed several times. My idle will be horrible when i start the car, it will go from 1,000 up to 2,200 than slowly as it warms up gets a little bit better. It is not my antifreez, and some say it could be a vacuum leak from when i put the skunk2 intake manifold on. It is extremely annoying and i cant ever get a answer to this problem, anyone have a similar or had a similar problem with theirs? PLEASE let me know if you have anything that can help me. thanks
Old Sep 12, 2002 | 07:31 PM
dubcac's Avatar
dubcac
I
Sounds like a vacuum leak, also check your idle adjustment screw.
Old Sep 12, 2002 | 08:35 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Is there air in your cooling system? That could cause a weird idle when the air pockets hit the iacv.
Dubs
92+ Civic/EL & Del Sol
18
Apr 23, 2004 04:48 PM
Dubs
Apr 20, 2004 01:16 PM
2cheap
Accord
4
Mar 13, 2004 06:35 AM
ramosr2540
Engine Swaps, Tech & Tuning
3
Jul 10, 2003 01:46 PM
