Code Identity HELP
Old Sep 11, 2002 | 10:27 PM
undrgrndhaqer's Avatar
undrgrndhaqer
Mr. EG
Default Code Identity HELP
I jumped my ecu to see what code I throw on my check engine light. It threw a 24 If you can believe that. I looked the code number up everywhere I could on the net and in my gsr shop manual and I found no 24 code. I have a gsr motor in my 92 vx civic hatch. I read the light correctly because it showed me 2 long flashes and then 4 short flashes. Then it repeated all over. If someone could found out what that code is, it would be very helpful because I am having a fuel problem. I have alot of excess fuel coming out of my exhaust. Clouds of smoke when I mash the pedal. It can't be coming from the regulator because the stock fuel is made for a sohc vtec-e motor and should run smaller fuel numbers from the pump and fuel regulator. I think my injectors are leaking extra fuel or something. Please help
Old Sep 11, 2002 | 11:13 PM
MikeSarr_GSR's Avatar
MikeSarr_GSR
yea man, I looked and all I see is 22-vtec system and 23-knock sensor... ?
Old Sep 12, 2002 | 12:20 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I don't see it in my Helm's either(it's a 96-00 Civic one, though). Are you sure you're not seeing a 4, and a 20?
Old Sep 12, 2002 | 09:15 AM
undrgrndhaqer
Mr. EG
I am positive its a 2 and then a 4 and then a break and then 2 and 4 and then break. I know its a 2-4. Two long flashes and 4 small ones. I cannot find that anywhere. Maybe its a mix up between my motor swap and my aftermarket ecu. That could be the problem. I got the ecu from ebay. Its a GSR ecu ... I think p72? Anyways its JUN chipped. But, can anyone help with the fuel issue. Thanks
Whitelude420
Prelude
May 27, 2003 05:20 AM
