no power to spark plugs?
Old Aug 31, 2002 | 09:38 AM
madlow's Avatar
madlow
Default no power to spark plugs?
I used the same plugs on another civic and they spark when you pull them out and crank the motor over while the spark plug touches the valve cover.
I am trying to start a 94 integra ls and it just cranks over w/o even coming close to starting. I need to know what are some possibilities why there wouldnt be any power going to the plugs?
All fuses are good.
Another idea is this car was in a rear end accident which deployed the air bags. Could there be some sort of shut off switch for the motor? I tried to look for anything obvious but no luck.
thank you!
Old Aug 31, 2002 | 01:28 PM
90'RS's Avatar
90'RS
Well if your not getting any spark I would start looking at your ignition. I would check things like your coil, ignition module, cap rotor. Good luck
And I don't think that a air bag going off will stop the car from running, as far as I know
Old Aug 31, 2002 | 06:07 PM
AwwsChwA's Avatar
AwwsChwA
actually yes, deploying the airbag for a lot of the newer cars (96 and up) shuts down the entire electrical system. It's a safeguard, since a lot of crashes big enough to trigger the air bags cause potential fire hazards.
But yes, check the ignition system. Maybe you could try putting the distributor cap/rotor/wires onto the other car. If it starts, you know it's not that. Then test the ignition coil. Chances are, the problem's gonna be somewhere in those parts.
Old Aug 31, 2002 | 07:05 PM
90'RS's Avatar
90'RS
Well hey I learn something new everyday. I never knew that the air bag could shut down the electrical system.
Old Sep 1, 2002 | 06:33 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
It's part of the inertial safety stuff that you need to re-set normally, sometimes not, but I have seen some cases where cars have inertial switches to shut off the fuel pump more than anything, to prevent fuel from being pumped everywhere after an accident.
-Harry
AIM: NDcissive
madlow
Engine Swaps, Tech & Tuning
2
Sep 9, 2002 08:44 PM
wales78
10
Jul 10, 2002 11:51 AM
AwwsChwA
7
Jun 26, 2002 08:18 PM
kcteggy
Jun 24, 2002 04:21 AM
