Andy
I think I remember you doing this. GSR rear brake swap onto a 92-95 civic chassis.
What are all the parts I require for switching from rear drums to rear GSR discs?
Also, will a Comptech rear sway\lower tie bar combo for a 94- Integra work on a 92-95 civic chassis?(given that I have integra rear LCAs)
Thanks in advance.
Thanks in advance.
LCAs, trailing arms, hubs, brake setup, and ebrake cable.
And the comptech sway bar will fit.
Technically, all you really need is the trailing arm itself (the huge ass piece everything bolts to) and the complete brake assembly, including the hub, rotor, caliper, e-brake cable and rubber line (or stainless replacement). The LCA is a good idea from a GS-R as it has the mounting point for a rear sway bar, but it is not nessicary, you can re-use your stock one. If your going to use the Comptech unit, you will most likely need them anyway. That also should bolt up, but I've never tried so I can't say for sure. Seeya.
