Compression test #'s to CR?
Old Aug 31, 2002 | 02:40 PM
ShootingStar's Avatar
ShootingStar
Default Compression test #'s to CR?
I just bought a compression tester and got these numbers:
#1 270
#2 265
#3 270
#4 272
This was with a warm engine, WOT & fuel pump disabled. When I bought the car I was told that the CR was 11.1:1 but have had no way to verify it. The motor has about 24k miles and is a B18C1 bottom end from a '96 GS-R with B16A pistons & new OEM rings, a B16A head with CTR cams, Portflow inner & ITR outer springs, OEM head gasket. The question is: Can the ACTUAL compression ratio be calculated from these compression numbers? Anybody got a GUESS?
Old Sep 1, 2002 | 01:11 AM
dubcac's Avatar
dubcac
I
No it can't. Compression test results tell you the condition of the motor, not compression ratio. You will get higher numbers on the test with a higher compression motor, but there's no way to calculate that.
Old Sep 1, 2002 | 11:13 AM
-KangaRod-'s Avatar
-KangaRod-
Captain
those numbers look really high though...which is a good thing (I think)
Old Sep 1, 2002 | 11:18 AM
Luis's Avatar
Luis
Civic1.6VTEC
as long as the numbers aren't more than 20 or 25 apart from each other. the motor is good.
Old Sep 1, 2002 | 10:11 PM
93si4ws's Avatar
93si4ws
ChinoRN
how about calculating the CR for a ls/vtec, crvtec, or 2.3vtec? i'm building the last one. 2.3 crank/rods with 2.2 11:1 pistons with .25mm/.010" OS. any help...thanks
v
R_Squared
4
Dec 28, 2005 05:14 PM
