Honing with a power drill?
Old Sep 2, 2002 | 09:24 AM
aut0tek's Avatar
aut0tek
Default Honing with a power drill?
My Machinist was SUPPOSED to hone my cylinders out... Instead he used a power drill and some brush-like thing with like 100 little stones in it... So there's no crosshatch pattern on it... just looks like I strapped a piece of sandpaper to a drill and went to town... is this bad? I think so. lol
Also, which is better... Aftermarket Rod/Main bearings or Honda ones?
Thanks.
Harry
Old Sep 2, 2002 | 11:54 AM
taylormadem5's Avatar
taylormadem5
well..thats one way to hone a cylinder...you can do it that way..IF YOU KNOW WHAT YOUR DOING...i have seen it done to a go kart engine several times and work just fine...and depending on what aftermarket company you are getting your bearings from..depends on which one is better..ask around..and see which are the best for the price your willing to pay
Old Sep 2, 2002 | 11:55 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You mean a flex-hone? If the cylinder was straight to begin with, a flex hone wouldn't be all bad, but if the cylinders aren't straight, that's another story. As far as the cross-hatch goes, that's all a matter of ring-seating, as long as you don't have a mirror-smooth finish on the cylinder walls, you should be able to get the rings to seat fine, although the cross-hatch is obviously preferred since it doesn't promote ring spinning or anything like that.
-Harry
AIM: NDcissive
Old Sep 2, 2002 | 04:35 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I hear ACL bearings are good.
Old Sep 2, 2002 | 09:17 PM
aut0tek's Avatar
aut0tek
Aight thanx a ton everyone... I'm going to assume the cylinders were straight to begin with... The block was in good shape in every other way when we took it apart, u know... bearings looked great, it mic's just fine... all within specs... U know.
I GUESS that's what it is... a flex hone... but who knows... The cylinders look rough, but feel pretty smooth.
We might see her put together in the next few days, too!
Thanks again,
Harry
Old Sep 20, 2002 | 11:03 AM
g2tegls's Avatar
g2tegls
MR, ftw
Correct me if I'm wrong, 1stGenCRXer, but isn't there only crosshatching when a lot of material is removed, such as in overboring?
Old Sep 21, 2002 | 10:41 AM
1stGenCRXer
No, you can get a cross-hatch pattern with a flex hone as long as the material is uniform diameter and free of major irregularities. Basically, you can get it if you're overboring, or you can if your honing a glazed, but otherwise good, bore.
EkcivicBeast
Engine Swaps, Tech & Tuning
7
Oct 8, 2005 10:10 AM
dustimus
13
Jan 15, 2005 09:26 AM
preludedriver99
Prelude
Aug 25, 2004 08:30 AM
