Quick question
Quck question... I just need to verify if there is anything else needed besides engine, tranny, ecu, and axles to swap a 94 B18C into a 90 dx hatchback. Thanks
Into a '90 DX? Your going to need a mount kit for any B-series swap. You'll also need a cable tranny, the hydro one attached to a '94+ Integra won't work. You'll also need an pre-OBD distributor, injectors and ECU along with the pre-OBD wiring harness. Probably need to modify the shift linkage as well. The '92+ cars they bolt in, the '91 and older have some issues. Seeya.
Sure, glad I could help. It can be bolted in, but there is going to be some work that needs done. Seeya.
white_n_slow
92+ Civic/EL & Del Sol
39
Feb 22, 2005 11:08 AM
