want quick accel
Old Sep 14, 2002 | 11:26 AM
xbladr's Avatar
xbladr
Default want quick accel
What is the best way to get some quick accel im not lookin for a lot of high end power thats no big deal to me at the moment i just want as much low end power and quick acceleration as possible. I know there cant be much because i only have a modified 96 civic dx but wat is the best way to achieve this. Is there any type of thing i can do to increse accel by maybe adjusting something on the engine. Please let me know thanks
Old Sep 14, 2002 | 08:32 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Tighten the throttle cable. :dunno: I've never done this, but they say it'll give you a quicker response. Maybe you can get a few ponies by advancing the timing too.
Old Sep 15, 2002 | 10:19 AM
b00gers's Avatar
b00gers
swap that engine...theres like 15 lb/ft of torque in there.
torque is what you want.
Old Sep 15, 2002 | 06:06 PM
xbladr's Avatar
xbladr
does anyone know how to tighten the throttle cable on a 96 civic dx thanks
Old Sep 15, 2002 | 06:17 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Loosen the two locknuts that hold the cable to the bracket on intake manifold and adjust them so that the tension between the throttle cable bracket and the throttle rotor is taught, with maybe 1/2" deflection. Once you get it where you want it, look at the butterfly plate and verify that it closes completely when the throttle is not engaged. This would be a good time to clean out your throttle body with some intake cleaner if you haven't done so in a while.
Old Sep 16, 2002 | 04:44 AM
xbladr's Avatar
xbladr
Where can i buy intake cleaner and how much would it cost and i havent ever done it and ive had the car for 1 year or so. Thanks i will try to tighten the throttle cable today. Also is buying a throttle rotor the same thing as tightening the throttle cable? thanks
Old Sep 16, 2002 | 05:37 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
auto parts store
like 2-3 dollars
no
Old Sep 16, 2002 | 06:04 PM
2 damn dark's Avatar
2 damn dark
advancing the timing on the dist......you turn it counter-...yes?
Old Sep 16, 2002 | 07:35 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
counter-clockwise: advance
clockwise: retard
Use a timing light, don't just guestimate or run it at full-advance. Generally you don't want to advance or retard more than 2 degrees from stock, which is marked on the crank pully. The white mark by itself is TDC, the mark in the middle of the cluster of 3 is your stock timing, and the marks on either side of it are 2 degrees advance/retard.
*these markings are for a B18C*
If you don't know the proper way to set ignition timing, go here:
http://www.c-speedracing.com/howto/timing/timing.html
Old Sep 17, 2002 | 12:33 AM
MikeSarr_GSR's Avatar
MikeSarr_GSR
put in a larger final gear and do what they said too
