D16Y8 head on a D16Y7...
Old Sep 4, 2002 | 02:00 PM
epx's Avatar
epx
Master of the Universe
Default D16Y8 head on a D16Y7...
Any words of wisdom before the fun begins?
Any small upgrades that work well with this head?
Thanks!
Old Sep 5, 2002 | 06:15 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: D16Y8 head on a D16Y7...
if you're gonna run the stock redline, no head upgrades are needed. bolt-on, find yourself the D16Y8 ECU, and you're set. Of course if you choose a high performance cam, then follow the recommendations of that cam.
If you wanna get some bigger power, run D16A6 (88-91 CRX Si) pistons in that D16Y7 block. That'll yield you roughly 10.5:1 compression. Then you got the option of overbore, balancing, etc etc. If you're willing to put in some serious tuning time, you can even run D16A1 (86-89 integra) pistons, that'll get you 11:1 compression, but it's gonna require more anti-detonation work.
Old Sep 5, 2002 | 08:30 PM
qtiger's Avatar
qtiger
This swap affect the CR of the d16y7?
Old Feb 8, 2006 | 11:17 PM
CIVIC_INTEGRA's Avatar
CIVIC_INTEGRA
Default Integra strip head bolts heli coil or rethread block
:( :confused:
I have a big problem my Integra just over heated do to 3 loose head bolts I found out that the block has 3 strip holes, If I try to torque down those 3 bolts they just keep on spinning freely, what is the best thing to do heli coil my block, or just re-thread to a bigger hold and ad a new size of bolts to my head, because I was told in Auto Zone in order to fix that problem I could not use heli coils on my block. I would have to re-thread and use a new size bolt, if this is true, is there a kit that I can buy to rethread and ad 3 new bolts, what is it called.
questip
Engine Swaps, Tech & Tuning
Jun 25, 2007 04:02 PM
99DxHatch
Feb 13, 2005 12:05 PM
xbladr
May 20, 2003 03:01 PM
ISP James
92+ Civic/EL & Del Sol
4
Sep 29, 2002 07:59 AM
sinthetiq
2
Sep 10, 2002 09:00 AM
