engine bogging when warmed up? not passing smog either :(
Old Aug 14, 2002 | 07:15 PM
dantastic's Avatar
dantastic
cx power!
Default engine bogging when warmed up? not passing smog either :(
im having a slight prob with my 93 CX motor (with 130k on it). i just need to fix it to pass smog
when the car is cold, it pulls hard. but when it finally warms up, it gets it feels like the fuel pressure dies and it bogs/feels really weak. it also idles a bit rough. When i try to accelerate hard, the CEL (#1 o2 sensor) comes on and the car drives normally again. the exhaust smells REALLy bad sometimes, so i guess theres something wrong with the fuel system? if i dont push the motor (kinda hard with only 70hp) the CEL wont come on.
ive changed the plugs, wires, cap, rotor, fuel filter, o2 sensor, and cat-conv. the wierdest thing is that when i turn off the car, adn turn it back on, the CEL dissapears. i failed smog the 1st time around (b4 the maintenance) with really high HC levles, and i dont wanna fail again.
you guys have any suggestions???
i dont have enough money for a swap yet (thinkin bout a d16z6 to hold me over for a while, b20vtec later) so i need to get this sucker working.
Old Aug 15, 2002 | 09:43 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: engine bogging when warmed up? not passing smog either :(
Ok, you said that it bogs when it's warmed up, but not when it's cold...can you make it bog at all if it is cold? My only idea would be that the fuel pump can't keep up. That would explain why it bogs when you stomp on the gas, but it doesnt explain why it only bogs when it's hot.
Old Aug 15, 2002 | 09:55 PM
dantastic's Avatar
dantastic
cx power!
hmm.... it only bogs right when the car is up to temp. after it bogs, the CEL comes on and the car drives like normal again. it doesnt really happen at all when its cooler than around 65 degrees outside. well im getting a new motor (well it has 50kmi on it, but its free!!!) next week. im gonnna use it to practice swapping engines and to try to pass smog
boots420
CRX & Pre 92 Civic
5
Feb 22, 2006 12:52 AM
eMpAtHy112
Prelude
Aug 26, 2004 06:20 PM
PRoth
Aug 20, 2003 06:00 AM
