why wont my teg start?
Old Aug 30, 2002 | 06:19 AM
madlow's Avatar
madlow
Default why wont my teg start?
I know there are many possibilities but I figure it has to be something I over looked.
I bought a 94 LS a couple days ago. The person who had it crashed it into a stone wall backwards(dont ask). So he had it parked behind his house and went out 2 weeks ago to take the intake off. The car did start at this time.
I checked the fuses and they were fine. Any ideas?
Old Aug 30, 2002 | 08:29 AM
kinghawk's Avatar
kinghawk
well Im assuming everything is put back in such as the intake??? yea? hope so. but do a basic check on things...... getting air? fuel? spark? see whats the culprit then go from there
Old Aug 30, 2002 | 10:06 AM
90'RS's Avatar
90'RS
Does the car attempt to turn over or does it just sit there when turning the key?
Old Aug 30, 2002 | 11:57 AM
madlow's Avatar
madlow
it cranks over fine but doesnt even sound like its goin to start.
Old Aug 30, 2002 | 12:07 PM
antennas up's Avatar
antennas up
Banned
could be a fuel line problem. maybe last time it started, it ran off the little amount of fuel that was in thelines, but now its not pumping anymore. just a possibility
Old Aug 30, 2002 | 02:38 PM
MoFo's Avatar
MoFo
Baddest mf'er...ever.
pull out an injector see if it spits, or for less mess put a screwdrive on top where the injector is plugged, and put your ear on the handle and see if you can hear it spit. (sounds redneck, but it works)
pull a plug wire out and arc it see if there is spark.
ghetto tip #2 spray some carb cleaner in the intake manifold as you are cranking it. once it starts, give it some gas, let it sit for while, then kill it and see if it cranks.
take a look at the dist. and the spark plugs as well.
Hot1990civ
Jun 6, 2007 11:43 PM
Megsteg
5
Sep 20, 2005 11:16 AM
Peeeezy
8
Jul 4, 2005 12:54 PM
madlow
Aug 31, 2002 11:12 AM
