H22 in an Accord?
Old Aug 27, 2002 | 02:40 PM
DanM's Avatar
DanM
Default H22 in an Accord?
I don't know much about Accords .. The Accords are J-series engines, right? Are Js and Hs compatible? Could you put an H22A4 from a new Prelude into an Accord? Would it be any good?
Old Aug 27, 2002 | 02:54 PM
90AccordEX4's Avatar
90AccordEX4
What year Accord? I am putting an H22 into my 1990, replacing the F22A4, it is a relatively simple swap...
Old Aug 27, 2002 | 03:15 PM
DanM's Avatar
DanM
I was thinking the newer ones actually, 98+. Would it still go easily into those?
Old Mar 26, 2006 | 04:00 PM
turbowagon's Avatar
turbowagon
HAY IF IT DOES LET ME NO I HAVE A SWAP I WAS SELLING BECOUSE I DID NOT THINK IT WILL FIT MY 91 ACCORD ITS AN H22A4 OF A 2000 SH NICE ENGINE DC HEADERS JC SUPERCHARGER SLEEVED CHIPED ALOT OF NICE OPTIONS ON THE ENGINE TURBOCHARGEHONDA@YAHOO.COM
Old Mar 29, 2006 | 06:42 AM
93teggy's Avatar
93teggy
yea the swap will work no problem....i have a friend that put an h22 in his 98 4 door.
Old Mar 29, 2006 | 07:21 AM
AcuraFanatic's Avatar
AcuraFanatic
That engine will fit into your 91 Accord, do your homework.
The 6th gen Accord (98+) uses the F23 for the 4-cylinder and the J30 for the V6 models.
The H22 is able to be swapped but it's a shitload of work compared to a 4th or 5th gen Accord. It's far from a straight forward swap with that model.
Best bang for the buck is to turbocharge the 4-cylinder F23 IMO in those models.
Old Apr 23, 2006 | 07:44 AM
turbowagon's Avatar
turbowagon
thanks i was told that i should use an accord tranny it will be better and obd 1 to obd 2 wire harness and to be carefull with the firewall i have to bang it in aboute an inch to fit the supercharger.
Old Apr 23, 2006 | 03:58 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
No don't waste the power of the Lude motor by mating it up to the tall gearing of the Accord tranny. If you are going to do it just do it all at once.
I run the 98 Prelude H22A4 open deck mated to a 98 Prelude transmission fitted with a Cusco LSD in my 94 Accord and I love it.
Old Apr 23, 2006 | 04:00 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
well Dan if your car is running the F series currently then the H swap is pretty straight forward. If your car has the J series 6 cylinder don't even consider the H swap into it.
I think that is about as simple as the decision can be broken down.
Old Apr 30, 2006 | 02:53 PM
turbowagon's Avatar
turbowagon
i heard that the tranny for the sh is a shit load of problemes for the swap i have my own shop and the tools for the swap i need help on what i need i have engine, tranny, ecu, axles, wire harness, mounts, and all engine parts alternator,starter ect. but is the supercharger a problem on the fire wall?
h22civ
Sep 28, 2006 06:16 AM
h22civ
Mar 7, 2006 10:48 AM
jtelliso
Prelude
Feb 19, 2006 05:45 PM
VoteNader
Prelude
4
Apr 6, 2005 08:44 PM
accordtypeslow
Oct 7, 2003 01:50 PM
