Coolant level and idle?
Old Aug 28, 2002 | 11:53 AM
MoFo's Avatar
MoFo
Baddest mf'er...ever.
Default Coolant level and idle?*update*
Car 93 CX Hatch
Engine B16A (some mods )
Timing fully retarded, and it still idles high
The engine in my car has had idle problems from the very begining. It would idle around 1200, until I adjusted the valves, then the idle returned to about a grand. (??)
Once the engine is fully warmed, the idle INCREASES, in traffic it has gotten as high as 2400 After cruising for a while the idle DECREASES back to a grand.
My friend knows nothing about cars, he has a 89 Accord which had a similiar problem. He went to a mechanic and the mechanic just told him to put more coolant in there, which he did, and the problem was fixed.
My coolant level is fine...but...I have the stock CX radiator. (I know, I know, Fluidyne is on the way)
Does coolant level affect the idle at all?
Old Aug 29, 2002 | 09:51 PM
93acuraviga's Avatar
93acuraviga
I'm not an expert at that category but I dont think it would affect it, as long as the engine temp isn't too hot or cold, the coolant wouldn't change the idle... but that's just me using common sense; anybody know the answer for sure??
Old Aug 30, 2002 | 04:16 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Timing doesn't necessarily directly affect idle speed.
That said, I think you may have a TPS or IACV "glitch".
-Harry
AIM: NDcissive
Old Aug 30, 2002 | 08:33 AM
kinghawk's Avatar
kinghawk
I would check for misrouted vacuum lines and or broken lines. also what was done to the fast idel solenoid on the intake manifold.......?
Old Aug 30, 2002 | 02:31 PM
MoFo's Avatar
MoFo
All vacuum lines have been accounted for, and are all connected correctly.
Interesting note about the TPS glitch, I picked up a TB with a new TPS in today, and will be changing it tonight, I'll post the results.
I appreciate the help guys.
Old Aug 31, 2002 | 12:25 AM
MoFo's Avatar
MoFo
Default Schweeet...
Well, changed the TB (with the new TPS) and car idles normal now.
Just a quick question though, how does a faulty TPS cause problems with the idle?
Old Aug 31, 2002 | 07:38 AM
1stGenCRXer
Default Re: Schweeet...
Fluctuations in voltage readings to the ECU cause changes in air/fuel mixture, so the ECU thinks the throttle is in a position other than closed and tries to work out something with the o2 sensor to get the mixture right, which is unnecessary since the throttle is closed.
I love it when I can nail a problem on the head first try
Old Aug 31, 2002 | 11:14 AM
MoFo's Avatar
MoFo
Awesome...thanks stud.
nees1212
92+ Civic/EL & Del Sol
Aug 11, 2005 09:47 AM
jordan88
15
Dec 31, 2003 11:59 AM
jaydub1996
9
Oct 2, 2003 12:51 AM
jordan88
3
Feb 13, 2003 04:32 AM
