- Can You Bore A Vtec
- Easy turbo question?
- b16a integra
- Running Rich
- Cold spark plugs for GSR turbo
- Missfire with my lude
- Hybrid
- What knuckles do i need
- Less Compresion
- Please help!!
- I Need To Finish My Swap
- K20 Info...
- f22 block
- fuel pressure regulator
- whats the highest compression you can run on boost?
- Not reving like it used to !?
- integra gsr swap [into CRX]
- engine timing help
- B16 OBD0 Head conversion to OBD2
- 96 Accord problems
- Considering designing custom data logger, what to add?
- Gears on a 89 civic
- DTC P0401 EGR Flow/EGR Port Clogging
- when is a bigger wastegate needed?
- VAFC Malfunction?
- v6 in a crx?
- Where to download Crome tuning program?
- Turbo running question
- b16 turbo need info please!
- intake for Honda 2001 ex
- help!!! just got my swap and the car keeps bogging down
- uberdata
- 250 whp??
- SRS light
- D16b2 ???
- B20 swap
- help!!! just got my car back and the vetc won't work
- my 88 CRX si project
- AC compressor turning on off, on off, ect..??
- 93 VTEC Running too lean ?
- b18c1 swap into 93 civic how hard to retain ac pz help
- Car Starter Piece Problem
- B16A problem.
- BOOST - (JDM)d15b VS d16z6
- compression Question
- have a few questions
- Few ?'s on JDM b18c into Civic
- H22 Oil Pump???
- Can i get a bit more power out of it???
- CRX/Integra Bushings
- short ram vs. cold air
- questions on rebuilding b18b for turbo
- RSX Throttle Body HERE NOW
- Where do I find b16a JDM parts??
- SAFC Question
- ITR Manifold
- 00 Si mid-powerband stutter - help!!
- Houston TX swap shops / tuners
- H23a
- where did you guys learn to build a motor?
- Honda Civic Si swap advice
- swap shop
- 2Q's: Stock Exhaust and sensor wiring
- this is a odd questtion
- What am I doing wrong?
- PCV valve is hiding
- MY swap is not that good
- Newbie here, need some help with hp gain
- 1.6 DOHC ZC Firing order???
- possible b20?
- Help no spark
- rebuilt engine, str blockguard, why cant i keep the engine temp down?
- 1990 integra engine swap
- suspension for a GSR hatchie
- LS or B20?
- turbo gsr
- Twin Charger Setup
- mini me swap
- 97 Accord V6 A/C problem
- b16a CYL sensor
- Need Major Help
- Engine weight?
- Manifold for B16a2
- b20/vtec question
- I suck at tuning. I need some help from you experts.
- '95 vtech-engine light-?
- need help on valve adjustment
- Found the problem
- honda cr-v ELC p0420: catalyst system not efficiency
- 94 honda civic 1.5
- Timing Question
- JDM H22 or Jdm B16 sir
- it won't fire up..
- What Aftermarket Internals Should I Buy For My B16c
- Higher compression ratio.
- Just want to make sure....
- Rebuilding: take a look at this combo...
- Speedchip?EBay ECU? BS?
- 95 Accord OBD1 ECU problem
- Guide to B-series cam specs...
- stock b16 sir II parts
- help from honda techs please
- B16a Gen1 Obd0 (vs.) B16 Gen1 Obd1
- Bad engine noises
- 91 accord -removed and reinstalled Balance Shaft Belt - won't start
- idle problem
- check engine light
- Timing question with jdm itr piston.
- misfiring?
- 95' Acura Integra cooling problems
- Let me know Pls?
- urgent: 2000 Honda CR-V engine check light on
- -=Bent crankshaft=-
- B16A 2 is it worth it ot go N/A?
- Help needed
- vtec engine
- O2 sensors?
- Acura Problems,help!
- Acura Problems, help!
- just a couple of tips...
- clutch or master cylinder
- what to do first?
- Crower cams?
- what should i use for injectors?
- clutch problem : clutch, master or slave cylinder?
- Turbo kit questions and tuning
- Odd Crackling sound at engine shutoff
- highest level of boost on a completely stock h22A
- power loss.
- ls/vtec problems
- ls/vtec problems
- How VAFC 2 works?
- headers
- Throttle body and Intake Mani Question
- Noob Q: VTEC CONVERSION
- Best pistons and rods???
- Anyone ever...
- bad injectors
- Which Setup Is The Best!! Please Help
- Rev Problem
- Engine Building
- Need help with these parts for turbo!!
- Which Manifold/header????
- Variable Nozzle Technology
- ls/vtec swap
- teggy is dead
- major problems help please [Integra w/ B20B]
- changing your fuel pump
- ys1 y21 tranny
- Tuning
- JDM ECU OBDII?? Can you smog it??
- powdercoating intercoolers?
- 92 LS won't start after 24 hrs.
- vtec turbo question
- 96 civic dx fuel pressure?
- VTEC improvement?
- Help I'm getting the run around with my 2002 3.2TL
- H-brace??
- Vtech not working
- cam problem??
- JDM b16a sir II into a 92 TEG /LS wiring harness question.
- engine misfiring
- Question.
- where to replace timing belt
- Shops In San Diego, CA that Drop Engine?
- Tuning for Dummy's!
- vtec Problem(help me Please)
- Best turbo kit for my setup
- Best tranny for f-series engine?
- EG Bar/Legal Swaps.....CA???
- What ECU do I have??
- 87 CRX with d16a1 speedo???
- Hybrid Engine.....What would you prefer?
- timing belt and waterpump question
- 06-08-05 Dyno tuning Gsr Turbo Pictures
- Vtec Cutting out
- B18C1 Civic VTEC Cutting out
- 90 Legend Speedometer not working...
- Unorthodox Racing Pulley
- going south
- Wondering...
- noise coming from starter/flywheel engagement
- throttle question
- SAFC II on a d16y9 engine
- Which Swap to do?
- b16a engine codes
- 03 Accord V6 Tranny Slipping
- K&N Intake Wierd Noise after engine turn off
- Need a good shop
- sohc vtec tranny
- How to reset Honda ECU.
- Cars nearly paid off, time to go faster!
- turbo b16a question
- turbo v.s Supercharger d16y8
- Engine Swap Help In San Diego
- 1999 B16A2 Head on D16Y8 Block
- what is the diff between open and closed deck?
- High compression d16y8
- valvetrain
- help me build a "perfect" ls/vtec
- vtec intake
- LS/Vtec Timing Belt
- Tuning a high comp LSVTEC
- Where to find B18C in SF/Bay Area?
- intake???
- TSB drivability issues.
- d16y7 swap.......
- Pr4 Ecu
- having some problems
- Dont rev past 3500
- external and internal wastegate differences?
- What year B18C to get?
- which would cool better?
- Exhaust Question...Please Help
- Front upper strut bar
- Aftermarket Torque Converter
- slow pick up and muffler noise
- need help with balancing b18b (ls/v-tec)
- Car will not warm up
- Any online vendors that have good prices on engine building tools?
- 5-28-05 D16Y8 Turbo Dyno Pics
- Skunk2Racing Cams
- crude forced induction
- Profec e-01 tuning
- 89 accord juiced up
- Manual Boost Controller Recommendations
- LS/Vtec Wiring
- new .
- ZC on to CRX dx Help!!!
- OBX radiator hoses?
- chipped p2p???
- throttle cable bracket
- good bad and broken
- ctr n1 crank pulley
- Acura Intergra Major Problems
- which tuning device?...
- Got it to work, now I need some suggestions
- b20b build
- Vehicle Performance Computer HP numbers through your cigarette lighter?
- Everyone You Must Know Something Here..please Read!!
- 2000 gsr..floating valve????
- high flow cat worth it?
- Shift linkage [B series swap]
- just swapped GSR into civic ex...was curious....
- Ceramic vs. Stainless Steel
- Need help with new turbo installation - overheats immediately!
- Pulleys???
- Muffler question
- B20/Vtec
