noise coming from starter/flywheel engagement
Old Jun 7, 2005 | 07:18 PM
xpman's Avatar
xpman
Default noise coming from starter/flywheel engagement
I've got a B16a that's starting to make a little noise when I start it. I doesn't do it every time though. When I turn the key, sometimes before the engine fires up, it will make a little grinding noise. Kinda like the noise you hear when you try to start a car that's already running (c'mon, you know that sound!).
Could the flywheel be missing a few teeth? I think if the starter was worn or missing teeth, I'd hear the noise every time. I haven't taken the starter out for inspection yet.
Old Jun 7, 2005 | 07:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like the starter is on its way out. If the problem gets worse, I would replace the starter.
It may be having issues keeping the gear engaged or disengaging it, so it grinds.
Old Jun 8, 2005 | 06:15 AM
JimBlake's Avatar
JimBlake
If the starter has had problems engaging, it may have damaged some of the flywheel teeth. Maybe, or maybe not; but you aren't gonna know until you remove the starter & look at it's pinion & look at all the flywheel teeth. Just remember only turn the engine forwards.
