b16a CYL sensor
Old Jun 28, 2005 | 04:34 PM
xpman's Avatar
xpman
Default b16a CYL sensor
My ECU is spitting out a code 9 (cylinder sensor). I've been told that its located inside the distributor. I popped it open, but I'm not sure exactly what I'm looking for, or how to replace it. Is it something that can be swapped out, or do I have to replace the whole distributor?
I see some little clear plastic thing that has 4 wire leads coming off of it. That's about the only thing that I might be able to call a sensor!!!
Maybe it's the circular thing that I would have called a "rotor" on an older car??
Old Jun 29, 2005 | 02:19 AM
xpman's Avatar
xpman
anyone, anyone??
Old Jun 29, 2005 | 04:10 AM
JimBlake's Avatar
JimBlake
The rotor is out at the end of the distributor shaft, same as in older cars.
The coil & 'ignitor' are easy to see, under there.
Then there's the 3 timing sensors, CYP, CKP, & TDC (code 9 is CYP). Those are little magnetic sensors that read from star-wheels way down in the distributor housing.
Problem is, I don't think you can buy just those sensors. You have to buy a distributor. Maybe the best you can do is buy a distributor without the coil or ignitor included.
Old Jul 9, 2005 | 09:25 PM
cartuner's Avatar
cartuner
Here's what you need to do before comfirming the sensor is bad. Good luck.
File Type: pdf
