throttle cable bracket
Old May 29, 2005 | 04:23 PM
krusty990's Avatar
krusty990
Default throttle cable bracket
I dropped the B18C1 into my '97 EKHB this weekend. Upon checking clearences I noticed that the throttle cable bracket that is attached to the throttle boby is quite high and the angle at which the cable will be forced to run will be even higher. I do not have the hood on the car but was wondering if another bracket is needed for this swap or will the stock GSR bracket work?
Old May 29, 2005 | 05:09 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It should work just fine. I had the GSR TB/bracket/cable on my motor for quite some time without problems. It's even better if you can get the bracket for the firewall that holds the cable down.
Old May 30, 2005 | 02:17 AM
krusty990's Avatar
krusty990
Thanks. I will look into the firewall bracket.
