H22 Oil Pump???
Old Jul 10, 2005 | 03:25 PM
aero3685's Avatar
aero3685
Default H22 Oil Pump???
I think I have decided that my problem lies in the oil pump assy. When I start up the car, it makes kind of a loose/wobbling metal sound. I cant find anything else that would do this, Im thinking its the oil unit inner/outer rotors having too much space between them.
When turning left... sweeping turns, my oil light will come on. And now it stays on for a second after the car is started, then goes off. The sound only lasts for 1-2 seconds until oil pressure builds up.
Would you guess that the oil pump assembly would come with new rotors? They arent showed in the picture.
http://www.hondaautomotiveparts.com/...R&vinsrch=null
Anyone know if it would be the actual pulley/gear (#2) that i should replace, or the whole assembly(#5)?
Car has been running good, I just dont want to end up breaking the pump. I dont think a oil pump gear would make a sound like this when starting though... And it doesnt look like I could just buy the gear separately. Any insight?
Are there any aftermarket oil pumps for h22?
Old Jul 15, 2005 | 09:26 PM
flatliner's Avatar
flatliner
Fix It
the pump wont do it. You wont hear the oil pump unless you used the same failing pump on a dozen motors before the noise. My point the gears are more oiled than any component. I think it is more pheasable to think your main berrings are torn up from a factory flaw of matching bore to color berrings.
