Pulleys???
Old May 23, 2005 | 10:12 AM
ABC_civic's Avatar
ABC_civic
Default Pulleys???
i saw some "AEM Tru-Power Pulleys" for like $170...i've heard good thigns bout pulleys but i've also heard they give u a rough idle...are these things a waste of $$$ of what are gains/advantages that you all have noticed...
P.S.-IF i get em' they're gonna go in a GSR motor thats in a 98 ex
the ones i was looking at---->http://www.performancepartz.com/index.php?cPath=542_574
Old May 23, 2005 | 11:19 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
They are a waste. The power gains are minimal at best and I have heard of fried alternators because of them.
Old May 23, 2005 | 08:08 PM
EviLLLLSiNz's Avatar
EviLLLLSiNz
n00b
it would be more beneficial to use that 170 dollars on something else like a intake or something
Old May 23, 2005 | 09:43 PM
Provocateur
On permanent hiatus
Or save it for gas money....
Old May 23, 2005 | 09:50 PM
fast99tl's Avatar
fast99tl
They aren't as bad as everbody been saying they are. You can usually expect about a 10 horsepwer on some cars a 20-25 horsepwer gain can be evident.
Old May 23, 2005 | 09:56 PM
Provocateur
On permanent hiatus
When I see the dyno charts, I will believe it but until then, I call :bs: on 10 hp.
Old May 23, 2005 | 10:00 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Well, wouldn't lightened pulleys be targetted towards reduced rotational inertia?
In that instance I wouldn't think that it would show up as numbers, so much as increased response.
Old May 24, 2005 | 07:51 AM
b16ahybrid's Avatar
b16ahybrid
lol, and the tornado really adds hp too.
I've never once seen an actual dyno chart of before and after (pulleys) that showed a gain of more then about 3whp somewhere in the powerband. I'd say at best expect 1whp from adding those pulley's.
Old May 24, 2005 | 09:17 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:lmfao: Prove it. h:
I've had these and they are worthless. In fact, they are actually detrimental to your charging system due to the fact that the alt. pulley is larger causing it to turn the alternator SLOWER. They are crap.
Old May 28, 2005 | 06:40 PM
twinring's Avatar
twinring
not only are they useless but the lack of dampening for the crank pulley will destroy your main bearings.
