Pulleys???
Old May 28, 2005 | 07:26 PM
OneslowredHB's Avatar
OneslowredHB
18 sec beast!
Originally Posted by fast99tl
They aren't as bad as everbody been saying they are. You can usually expect about a 10 horsepwer on some cars a 20-25 horsepwer gain can be evident.
and a intake will give you 15 H.P.
and a muffler will give you 10 H.P.
:huh: Man my car must be puttin out 130 H.P. then!
Ssssuuurrrrreee it does.
:huh:
Old May 29, 2005 | 11:02 AM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
I heard that a modernish car (90s) will compensate for the loss in accessory power by turning the pulleys faster, thereby negating any added benefit. Anyone else heard that?
I don't know why they don't just make light aluminum pulleys that are the same size as stock.
Dan
Old May 29, 2005 | 11:54 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
think about how the pulleys are tuned... by the crank. It's not as if your alternator will mystically turn faster just because it's not generating the power it should... h:
Old May 29, 2005 | 07:34 PM
b16ahybrid's Avatar
b16ahybrid
Dan
Being that it's belt driven I doubt they are going to spin faster then the belt.
Old May 29, 2005 | 07:36 PM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
It does sound weird... maybe it was like the alternator increases its output independently of the speed? :shrug:
Dan
Old May 29, 2005 | 08:11 PM
civicandtegra's Avatar
civicandtegra
well dosent the size of the pulley change the speed and the amount force needed to move it, take a bike and break down the different tires, thin light wieght tires turn faster more easier than chucky, a large road tire on bikes takes more to start it going but also makes it easier to spin at high speeds but a small wheel the power spinning it has to work harder to make it spin at high speed but has better low speed response (also take into account the different gears on the bike, aerodynamices, size on rider, etc...) i think there is a lot of variables that come into acount on this so untill i see a dyno chart that proves any major gain i think its a waste of cash and gas is expensive now... tear (armstrong pyhsics here)
Old May 29, 2005 | 09:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Dan
If that were the case, why would it even need to be hooked up to the crank anyway?
The alternator and all other accessories run directly from the crank and have no other outside force that powers them besides the crank. If the pulley is larger, the alternator is spinning slower, thus a marked drop in voltage is seen.
www.howstuffworks.com will give you the rundown on how these accessories work and the pulley size is relative to their functionality.
I guess if 1-3 whp is worth frying your alternator over, by all means, go for it.
Old May 30, 2005 | 01:48 PM
FATHONDA's Avatar
FATHONDA
170$ i got mine off ebay for half that I know there is a difference, but you have to dial it in correct or else its just a pretty addon.
Old May 30, 2005 | 03:31 PM
Provocateur
On permanent hiatus
You are thinking of adjustable cam gears. Accessory belt pulleys are completely different and they don't need to be tuned.
Just slap them on and watch your alternator fry.
Old May 31, 2005 | 12:28 AM
Project_ITR's Avatar
Project_ITR
AEM pulleys dont do anything because the main power adding pulley is the crank pulley which AEM doesn't make...if you wanted power from a pulley set you should have gone with UR
