VTEC improvement?
Old Jun 13, 2005 | 08:05 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Default VTEC improvement?
Is there anyway to improve the VTEC function other than it's engagement point? I was curious if there's upgrades, selenoid swapping, etc to make it more efficient. Maybe a performance oil pump, changing the wires, or alternator?
I've notice there is times the VTEC engagement comes on very strong, and sometimes i have to let off the gas a little and go WOT again to make it run faster.
Old Jun 13, 2005 | 09:29 PM
pomansouth's Avatar
pomansouth
you may want to check your oil screen in the solenoid, also it may be mental. The butt dyno is never correct... Anyhow, there is no other way to make vtec more efficient besides move the point up depending on how high you rev and also, the cam and other things... The best thing to do when tuning a vtec motor on a dyno with some type of tuning device better than a vafc is to move the vtec point up until the vtec engagement is practically smooth with the rest of the curve, this way you are getting the most before the curve and after the curve that there is possible.
