new .
Old May 30, 2005 | 01:44 PM
FATHONDA's Avatar
FATHONDA
Default new .
I have blindly made mods on my acura for years, now i am into my honda 89 civic, right now i have a 30 punch gp top rings, polished bottom end all. the head has new ex valves. someone guide me please the steps internally needed to make a monster out of this whatyamachoo. I dont want to hear about bolt ons at all, just engine internal tips like cutting excess guides to match input,output flow, etc. thanks
Jesse.
Old May 30, 2005 | 03:33 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sleeves, higher compression pistons, higher lift/duration cams, etc, etc.
You need to be more specific on what your power goals are and what you are building it for.
Old May 30, 2005 | 03:37 PM
Snoopy's Avatar
Snoopy
been there done that
knowing what motor you have would help
Old May 30, 2005 | 03:39 PM
steven_SA's Avatar
steven_SA
Default South African Turbo Art
My name is Steven highet and I recently move to the usa from south Africa what we basically look at out there when turbo charging our cars is,
The numbers not the parts
Compression ratio
Pistons
Feul management (After Market ECU)
Dynoed and Tuned 100%
Look at rated power on stock parts and work out what power you want to make then see what will need to be changed. You don’t always need 600hp rods when all you are looking to make is 350hp. You don’t always need a T3/T4 when all you are going to be boosting is 8 psi you could get a turbo match to the power you want to make.
