High compression d16y8
Old Jun 5, 2005 | 10:48 AM
honda_76401's Avatar
honda_76401
Default High compression d16y8
I've almost came to the end of the bolt on battle with this engine and i'm not wanting to turbo it, I was wondering is it worth it to put high compression pistons in the d16? What kind of hp gain should I expect? Thank you for your time.
Old Jun 5, 2005 | 01:14 PM
b16ahybrid's Avatar
b16ahybrid
it depends on what you want out of the car. If your looking for a fast car then no it's not going to happen, if your looking to gain a little more power and put those parts you already have to good use then sure why not. I'm not a N/A guy but I once heard that bumping your compression 1 full point equals about 10hp (going from 9.2:1 to 10.2:1). but thats also dependent upon your tuning. You may get more or you may get less, it's just a round about number.
b16ahybrid's Avatar
b16ahybrid
oh and you also have to consider depending on how high you go you'll need to run premium gas (91+)
Old Jun 5, 2005 | 01:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Unless you swap, the only way to get a good amount of power out a D-series without breaking the bank is forced induction.
I suggest you do one or the other because N/A on a D-series is a dead end road.
Old Jun 5, 2005 | 04:33 PM
Paulll's Avatar
Paulll
Hail Bent
if you want to spend 1000$ for 135hp, do it
Old Jun 5, 2005 | 06:17 PM
honda_76401
forced induction it is then, thank you
