- Prelude problem
- Help!!
- Are all b16a2 noisy?(small ticking)
- Help!!!!
- gsr pistons in ls/vtec
- Shops
- lean burn issue
- bigest bore! B20 and beyond
- 96 Honda Accord Car Running Problem
- Clutch 1989 Acura Legend
- 88crxsi $2500 b-series or h22a
- Oil on tip of spark plug wires
- Obd1 Dohc Zc?
- Wiring question
- Re-Build....B16a1
- Throwing me for a loop
- Supercharge 90-93 integra da
- Auto-Man. Tranny Swap
- project ghetto d this summer
- CTR Rods (Are they worth it)
- I Have A Trunk Leak!
- OBD-II in Civic '97 ?
- 98 Acura SLX Fault
- So I spun a rod bearing....
- tachometer wire colors, wiring diagrams
- Nitrous for h22a accord auto
- B18 into crx problem
- Installing S-AFC need info.....
- Transmission help please!
- ZC Swap - knuckles/hubs
- o2 sensor ???
- ls cam bolts ???????
- s2000 in 91 ls teg
- Bosting on a 95 mm crank
- b16 with b18 tran is that ok
- b16 w/ no spark
- 1997 Accord Cold Air Intake Problem...
- Accord Vibration and A/C problems
- Why does it turn off?
- Transmission Help (Tranny Case & Bearing Size Issue)
- VTEC feels weak...
- Did I cause any damage to the engine?
- Nos setup
- Wireing for P28/B20b
- will this tranny fit??
- OBD2 tool recommendations
- I have a knocking noise!
- 01 GSR dipstick tube?
- what is needs to be changed on a LS block in order to rev to 8k safely?
- Oil Pressure Gauge
- honda civic ex upgrades
- oil pressue
- NSX VIGOR fuel pump rating
- engine weights
- Pressure plate question
- Exhaust question after swap
- Mocking up a variable length intake
- my new motor ..... but
- 95 Civic Ex Wont start In CarThief Haven
- Engine Installers?
- #2 piston flooding
- cap and rotor
- Another ECU post...
- h22 help wrong thread but need answers now,help
- help wont run in gear
- Engine tuning
- Uberdata Question
- need opinions think i found the problem
- 1991 civic standard B18 swap question
- need a little confirmation
- BRAND newbie asking advice...
- D16y8
- many many civic parts to get rid of
- High / Low Rev At Idle
- cold starting problems
- o2 sensor
- tranny? not lockin!!!
- i should know the answer to this...
- need help with aftermarket underdrive crank pulley belts
- sorry
- MAP sensor Help or advice
- tips on first engine upgrade
- Need help with B20 swap
- Urgent! Need help with swap!
- Zex questions.
- Holley Header?
- Are There Any Superchargers For The 2004 Tl Yet
- help!!rear suspension bolt!!!
- Help! Help! Help!
- I need a Granny....er i mean Tranny!!
- B16 block code
- Engine question?
- Auto To Manual Conv.......
- IHI RHB5 VJ11 turbo for sale, should I buy it? HELP!!!!!!!!!!!!!
- ARP head bolts question
- gsr turbo questions!!!
- So I should've been revving my engine higher?
- new to this wot is the capabilities with b18c4
- rod Bearing
- Oil pressure or oil temperature monitoring
- how much to offer....
- what about h22 head on f23 block
- turbo manifold for h23
- Please help me
- Honda Techs
- b16a wiring issues
- Which Tranny is best for my car??
- Bit off too much?
- need instructions for b16a swap
- Electronic management for turbo
- Forced induction setup 1st time honda builder!!!
- GSR pistons in LS compression ratio? HELP!
- Exhuast Help
- ECU Tuning help....
- Nitrous...my plugs...and octane rating
- Oil pan baffles
- Misfire? Need Help!!!!
- B16 head on B18 block
- Manual Tranny???
- help with 95 hatch
- Online H22 Engine's for sale?
- Accord engine swap
- AC Compressor Locked Up!
- si into hf ?'s
- valve jobs
- engine swapping
- b18b block help!
- Best way to lose the speed limiter?
- Ls/Vtec exhaust
- valve adjustment gone awry
- Accord Antifreeze Reserve Tank Issue
- Help prove a point to Mustang owners!!!!!!
- Electrical issues After ZC swap
- D17a2
- to all of the machine gurus
- Emission Test Results
- b16 running hot help....
- B18c1 swap..??
- Will I need a after market clutch with zex nos
- Honda Accord Service Manual 2004
- K24a2 into a 5th Gen. Accord
- How to : Tuning Safc ???
- Concerning the conversion
- F22B into 99 hatch NEED INFO
- B18C1 what ECU?
- how much hp do I have?
- Spark plugs soaked in gas
- Which head would work for me better?
- engine blowing white smoke
- B20 Sort Block With Ls Head? Help!
- Engine Assembly From SCRATCH. Sohc, Pics, Links, Guides??
- How much will stock B18B rods take with ARP rod bolts?
- Port and Polish anyone?
- smoking-oil in cat?
- wipers are possesed
- ECU Help
- supercharger
- For you turbo junkies...i've got a few Q's
- Why is it so hard to find a turbo manifold?
- slight miss at idle
- Is this a hi-flow cat...or...???
- fuel grade?
- Could this be my power steering pump?
- Moisture in Exhaust??
- Questions about manual transmission fulid change.
- turbonetics evolution wg
- Measuring D16 Crank For Bearing Clearances. Where are the oem sizes stamped?
- d16y8 d15b8
- LS SWAP? Please read..
- EGR or no EGR?
- Anyone know any engine builders in mass/rhode island?
- No Start 2000 Civic Hx Manual
- stock airbox
- b16A exhaust header flange and T28R flange
- Do I have camber kits?
- tranny problems
- Turbo - Learn Me
- LS vtec pistons
- Vibration at idle w/ AC compressor on
- Snooping the ECU maps with just laptop, cable, and s/w
- Will a test pipe.....???
- Turbo vs. Nitrous...need help
- Let me know what you think about this.........
- Anyone know stock dyno?
- D18 pistons in D16
- What next?
- Turbo issues
- Gsr Block question..(smoking alittle)
- How to rebbot computer system in Accord 2001
- B16A Swap Question
- Milky under oil cap HELP??
- Lookin' at new intake manifold.
- Can I get 500+WHP from my setup?
- What with b20z ??
- im new please help
- Exhaust help
- What is Mugen exactly????
- vtec problem
- D15B2 + D16A9 Head Swap Question
- whcih one to choose?
- Is nitrous safe?
- 94 civic lx engine swap help
- 96 Civic Vti Immobiliser ECU
- Engine will not start after swap.
- code p1456
- motor knock
- car misses really bad
- h23 swap into ek questions
- acura integra transmission question
- Question about LS-VTEC
- turbo manifold fitment
- Intake/Exhaust Questions
- Is this a decent catback?
- possible power steering pulley
- 97 civic ex motor knock
- no spark / head gasket same time?
- help!!!!!!!!!!!!!!!!!plz
- newbie question, help appreciated!
- gsr/type r gettin taken out by a civic.....
- What year and model was this manifold from?
- Small Oil Leak
- Weird vibration
- I am having a problem on my honda prelude sh ecu?
- Need some help
- No Heat
- Anyone tried and H22A in a hatchie?
- Brake Light is ON in my dashboard panel
- £5 performance chip from eBay - opinions please!
- Manifold and Wastegate QUESTION!!!
- 99 hb wire harness (dx\gsr)arcing guestion does any body know ??????
- mods mods mods
- Vtec Wont Start
- Swapping in a H22A
- what ratio would you recomend turbo b16a1
- Simple question, WTF is this part?
- vigor turbo
- 87 Integra swap....
- Quickest??
- engine ?
- what HP/kW to expect? F22B1
- b16 ring markings
- Just wanna show of my hybrid!
- vtec blow plug
- 1994 HB..... Swap:1996 OBDII B18B
- Go fast CR-V
- 99 B18C1 into 2000 Civic EX Coupe
- pw0 ecu
- Battery
- VENOM Mani. Making IACV work. *pics*
- Anyone know how good they are
