b16a wiring issues
Old Feb 22, 2005 | 11:32 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Default b16a wiring issues
Hey, I've got my motor mostly wired up, but I've run into a few issues. Please give me your insight on these. BTW, the swap is a jdm b16a (obd1) into a '92 civic vx.
First issue: Where does the knock sensor wire up to? The wire coming off the knock sensor is not OEM and its cut, so I'm clueless.
Second issue: What are the two sensors on the left side of the head (pictured with arrows)? And where do those guys wire up? They are both also cut.
Third issue: Mystery connector (pictures 2 and 3). Its not attatched to anything. Any ideas as to what it might be and where it goes?
TIA (josh, I'm looking in your direction)
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 22, 2005 | 11:46 AM
white_n_slow
it's my D in a B
OK, i figured out the vtec solenoid and oil pressure... I know where they go on the ECU, so I'll just run a wire all the way back. Solenoid = A4 and Oil pressure = D6? Please correct me if I'm wrong.
And the knock sensor goes to B3?
:edit: still open to ideas for the mystery connector.
