How much will stock B18B rods take with ARP rod bolts?
Old Feb 12, 2005 | 08:03 PM
j87w's Avatar
j87w
Default How much will stock B18B rods take with ARP rod bolts?
My question is exactly that.
Old Feb 12, 2005 | 09:29 PM
b16ahybrid's Avatar
b16ahybrid
I've seen about 350whp on those rods. IMO you should be safe if you keep it at about 350whp. The factory cast pistons are the weaker point in the motor and they are good for about 300whp.
Old Feb 12, 2005 | 10:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You could get them shotpeened and improve the strength of them a good amount.
Old Feb 12, 2005 | 10:20 PM
j87w's Avatar
j87w
So shotpeened with ARP Bolts? Have you guys check out the forged rods from sparkracing.com for the b18bs? They are asking like 210 for them. I might just go with those. Im building a 190-200 HP LS Vtec Setup with a rev limiter NO higher than 8600. I was thinking I might be able to get off using the stock rods with ARP bolts for that. Im using type R pistons.
Old Feb 12, 2005 | 10:48 PM
Provocateur
On permanent hiatus
The stock rods should be more than sufficient for that kind of power. You could shotpeen them for the added security but aftermarket rods are complete overkill. Like you said, stock rods with ARP bolts would suffice quite nicely.
Old Feb 15, 2005 | 08:39 PM
j87w's Avatar
j87w
Has anyone had a LS that revved over 8k rpms with stock rods?
