Milky under oil cap HELP??
Old Feb 7, 2005 | 12:11 PM
EK9's Avatar
EK9
Default Milky under oil cap HELP??
Well to start things off im driving a gsr (b18c1). I just did an oil change and i happend to look under my oil cap and notice a milky white substance mixed with my oil. I heard it was a bad head gasket and oil and coolant is mixing up. Would it be safe to drive it like this, or would i have to get my head gasket change asap? Anyone with advice please let me know.
Thanks
Old Feb 7, 2005 | 12:16 PM
waypastfast's Avatar
waypastfast
Default Head Gasket
Change it now!
Old Feb 7, 2005 | 02:09 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Do a compression test to confirm. When you pulled the oil out, was it mixed with coolant or just the milky substance. Doesn't look good though. Good luck.
Old Feb 7, 2005 | 09:04 PM
EK9's Avatar
EK9
Well actually i didn't notice the milky white substance in my oil when i changed it. I noticed it when i decided to look under my oil cap. It only seems to appear in my oil cap not my oil when i did my oil change. Also i just swap out the head gasket about 3 weeks ago and i torque it to spec. Is it required to remove it guys?? Or should i do a compession test first to see if its leaking? HELP!!!
Old Feb 7, 2005 | 09:25 PM
Provocateur
On permanent hiatus
I don't think I understand what you are saying. Did you reuse the old headgasket or use a new one? If you used the old one, it will not seal right and you will have to tear it apart again and use a new one. You can only torque a headgasket down once.
If you used a new one, did you get the head resurfaced? Do a compression test to make sure everything is fine. The tester is cheap, so it wouldn't hurt.
Old Feb 8, 2005 | 06:55 AM
JimBlake's Avatar
JimBlake
Some condensation is normal if you somewhere cold & you do lotsa short trips & park outside.
Old Feb 8, 2005 | 10:22 PM
BoostedITR41's Avatar
BoostedITR41
you can reuse it but you have to spray it with copper before hand. still not the best idea though.
Old Feb 8, 2005 | 10:40 PM
Provocateur
On permanent hiatus
I would rather pay $60 for a new one than chance reusing the old one to find out it leaks after putting everything back together.
Old Feb 19, 2005 | 07:01 AM
needspeed's Avatar
needspeed
needspeed
I would take a part the head and seand it out to get check to see if you do not have a little crak in the head . Also it is recamened to put a new gasket very time you tear it a part.
Old Feb 19, 2005 | 03:49 PM
intensehatch's Avatar
intensehatch
ntense imports raceing...
I agree, always use new gaskets when ever you do any repairs like that
