b16 with b18 tran is that ok
Old Mar 10, 2005 | 10:17 AM
civicandtegra's Avatar
civicandtegra
Default b16 with b18 tran is that ok
i am gettin a jdm b16a vtec i was wondering if it would fit my b18 tranny on my 91 ls tegra and if i would need a new ecu and if i do what do should i get and the prices
Old Mar 10, 2005 | 11:36 AM
Snoopy's Avatar
Snoopy
been there done that
i will fit but i do not recommend it. the ls gears are too long for a b16a.
Old Mar 10, 2005 | 12:24 PM
reynosop's Avatar
reynosop
if your planning to boost the tranny should be ok !
Old Mar 10, 2005 | 05:44 PM
civicandtegra
yea i wanted to boost it but not right away
Old Mar 10, 2005 | 05:48 PM
reynosop's Avatar
reynosop
then in that case do what Mr. snoopy told you..
Old Mar 10, 2005 | 07:07 PM
b16ahybrid's Avatar
b16ahybrid
The car will be kind of sluggish because the ls has longer gears then the b16 tranny. You should be able to pick up a cable b16 or b17 tranny for pretty cheap. I would highly recomend going with shorter gears. The ls tranny will be too long IMO unless you run smaller tires or plan to have tons of power and need the top-end...
