b16 ring markings
Old Jan 24, 2005 | 08:09 AM
jamesmeister's Avatar
jamesmeister
Default b16 ring markings
I just got some new piston rings for my b16a motor from JE Pistons. The top combustion ring and the second combustion ring have a little "N" etched in them. Does this designate a "this side up" marking or is that just a manufacturer's tool mark? what exactly is that "n" for?
thanks
Old Jan 24, 2005 | 11:42 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I know that the manufacturing marking has to do with the orientation but I am unsure as to which side it faces. I will check my service manual when I get home because I think that there is also a notching that designates which side faces up.
Old Jan 24, 2005 | 10:30 PM
Provocateur
On permanent hiatus
OK. Just checked it. Manufacturing marks face upwards. There is also a chamfer on both the top and second ring. The top ring chamfer faces toward the piston and the second ring chamfer faces toward the cylinder walls. Hope this helps.
Old Jan 25, 2005 | 08:59 AM
jamesmeister
sweet man, that'll do it. thanks
