what is needs to be changed on a LS block in order to rev to 8k safely?
Old Mar 6, 2005 | 07:15 PM
Mackenzie C's Avatar
Mackenzie C
Default what is needs to be changed on a LS block in order to rev to 8k safely?
just the pistons or rods too? or the whole crank, rods, and pistons? if so what oe internals would you have to get?
Old Mar 6, 2005 | 08:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
A main cap girdle and oil squirters should be sufficient.
Old Mar 7, 2005 | 07:53 AM
ISP James's Avatar
ISP James
DAMIMRED
get stronger rods, too.
it might also be wise to get a higher volume oil pump such as gs-r/itr pump
you can get a gs-r main girdle, oil pan, windage tray etc and you'll be all set.
but with stock internals, it wouldnt be worth it, the ls wont make any power in RPMS that high. you will want to get higher c/r pistons and some new cams.
Old Mar 7, 2005 | 10:58 AM
qtiger's Avatar
qtiger
If you don't replace the rods, replace the rod bolts. They're a weak point.
Old Mar 7, 2005 | 11:01 AM
ISP James's Avatar
ISP James
DAMIMRED
keep in mind that if you only use aftermarket (ARP anyway) rod bolts, you will have to have your rods machined to use them or else you will have to worry about the rods getting mis-shaped.
Old Mar 7, 2005 | 11:05 AM
qtiger's Avatar
qtiger
Well iirc the vtec rod bolts are slightly larger in diameter than the nonvtec, so machining will be required even if he were to go with a "better" OEM bolt.
Old Mar 7, 2005 | 05:42 PM
robert f thomas's Avatar
robert f thomas
here is what I have prepared:
B18A1 block
1 lb shved polished balanced B18A1 crank
Eagle rods w/ Arp 8mm rod bolts
"Honda" bearings - rod main thrust
Pro fab 3 main girdle
B18A1 flywheel (not lightened)/ stage 2 clutch/ S1 trans
Fluidampr crank damper - single spool
Type R oil pan/ pickup/ windage
GSR oil pump
VTEC timing belt and VTEC water pump
3 things make me feel good = ARP rod bolts, 3 main girdle, fluidampr. If the internals are balanced.... "When you put your hand in a pile of goo that a moment earlier was your best friend.....you will know what to do!! and I don't want to hear that you are retreating. This Army will not retreat!! You will attack!! Spill thier blood!! Make them dead!! Make them retreat!! We will grab the 'Hun' by his nose and kick his butt from here to Berlin!! We're going to go through the German Army like shit through a goose!!!" George to his WWII Army.
Old Mar 21, 2005 | 07:35 PM
Mackenzie C
what oem internals would you guys use? ctr pistons, gsr rods, gsr crank, gsr girdle, etc..? and where could you get oem internals?
Old Mar 22, 2005 | 06:27 AM
ISP James's Avatar
ISP James
DAMIMRED
if you use any crank and rod combo but LS, it defeats the purpose of using an LS bottom end. you must use LS rods and LS crank, you cant mix and match. whatever crank you use, you need matching rods.
i would go with b16a (PR3) pistons for a streetable c/r
you can use OEM gs-r/ITR main girdle but keep in mind, with this you need to use a gs-r/ITR oil pan. you would also want to use a gs-r oil pickup and windage tray along with a gs-r/itr oil pump. thats just precautionary stuff. you can usually find all of this stuff in one sweep on ebay.
Old Mar 22, 2005 | 06:37 AM
crazy4396063's Avatar
crazy4396063
honda
do your really want to go through all the trouble to see 8k on your tach? just drop in a b18c1 or b16a ls is a good engine in all but if you want more rpms to reach your peak power get rid of the ls
