tranny? not lockin!!!
Old Mar 1, 2005 | 01:03 PM
moogotzskillz's Avatar
moogotzskillz
Default tranny? not lockin!!!
as yea'll know i got me a accord ex 5spd, and some times when im' on a light or about to go, my 1st gear dont go in u have to move it to neutral and try until it works? and it doesn that on reverse soemtimes?
as it happend to any of you honda techs????
does that mean i need to change my tranny fluid???(i know with HONDA MTF)
Old Mar 10, 2005 | 06:29 AM
ACK94's Avatar
ACK94
Life is FUN!!!!!
im curious too, mines does the same thing some times!!! Do you sometimes need to push a little harder than normal??
Old Mar 10, 2005 | 07:55 PM
augy's Avatar
augy
http://auto.howstuffworks.com/transmission6.htm
Take a look at this page. It'll also tell you why letting your car roll a couple inches can make getting into gear easier, especially in reverse.
Old Mar 18, 2005 | 06:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have that issue sometimes too and I found the best way is to put it in neutral, release the clutch, depress the clutch and try again for 1st gear.
Old Mar 18, 2005 | 07:43 PM
Provocateur
On permanent hiatus
i think you also need a new synchro also
Old Mar 18, 2005 | 07:44 PM
Provocateur
On permanent hiatus
does your first gear move forward without releasing the clutch
Old Mar 20, 2005 | 04:18 PM
crazy4396063's Avatar
crazy4396063
honda
try and hold the shifter in the 1st gear or reverse position and slowy release the clutch this worked great for me .....when i was running my sohc it takes some practice but you'll get the feel for it
Old Mar 20, 2005 | 05:59 PM
sp00nfKeD's Avatar
sp00nfKeD
your gear selector fork might be grabing 2 gears at 1nce, (just a thought), mines did.
