Help!!
Old Mar 20, 2005 | 10:23 AM
turboB16's Avatar
turboB16
Default Help!!
i just swapped out my 97 d16y8 with a jdm b16a......what is the best ecu for my car??? also my tach and speedo were working before the swap now only my temp and fuel are the only gauges that are reading??? Also there is only 2 plugs coming off my wiring harness do i get a computer that has 3 and only utilize 2 or do i get an ecu that has only 2???? Or is there something i am missing????? thanks peeps
Old Mar 20, 2005 | 11:42 AM
crazy4396063's Avatar
crazy4396063
honda
im running the p30 ecu.........which is a plug and play for you since you have vtec but there might be a extra sensor....from your old sohc engine....also check all sensors and make sure the speed sensor is plugged into the tranny the p30 is what you need but there should be extra wire not need for the p30
Old Mar 20, 2005 | 02:45 PM
turboB16's Avatar
turboB16
cool man thanks....Anybody else have any suggestions??
