Do I have camber kits?
Last year I was in a minor accident that screwed up my alignment. When they couldn't get it aligned properly they said I needed a camber kit to adjust the front and rear. Well I'm thinking of lowering my car and don't know if I'll need a camber kit for the front and rear. I probably wont lower it that much, but it would be nice to know if I have the kits so adjustments can be made if necessary. Is there anywhere I can search on here for pictures of what a camber kit for the front and rear look like? From what I understand the kit for the rear is just a couple of bolts...any help would be greatly appreciated...Thanks
and sorry that this isn't necessarily "engine" tech and tuning, I just didn't see a better place to ask the question
It would probably be better to post in the section of your car. I know my 91 crx si does not have camber kits. The camber is not adjustable unless you get the kit for my car. But then again, i adjusted my camber back to normal by putting the stock springs back on. My tires wore out in no time becasue the camber was so far off. I bought it lowered with no camber kit installed. Little did i know then. You can go to yahoo or google and search for camber kit.
