Are all b16a2 noisy?(small ticking)
Old Mar 20, 2005 | 09:16 AM
crazy4396063's Avatar
crazy4396063
honda
Default Are all b16a2 noisy?(small ticking)
i need some comfort......i just dropped in a jdm b16a2 in my del sol......and it is a lot noiser then the sohc.....it has a small constant ticking sound coming from the head.......is this engine common for doing that?....the engine has 25k -30k on it. its really clean too!
Old Mar 20, 2005 | 09:45 AM
turboB16's Avatar
turboB16
they are more noisy than a single cam but the ticking might just mean that your valves need to be adjusted....
Old Mar 20, 2005 | 10:08 AM
crazy4396063
honda
yeah there a marks from someone else adjusting them with a socket are there but my buddy has a teg and a prelude with b20 and those are both pretty noisy....if i go a long time without a valve adjustment will it hurt the engine? say a month or two?
Old Mar 20, 2005 | 10:16 AM
turboB16's Avatar
turboB16
i wouldnt suggest it but its a honda dude the thing can run on 2 cylinders and it'll still keep going but ya try to get it fixed asap by a certified mechanic at a honda dealership or something.
Old Mar 20, 2005 | 02:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will also accelerate the wear of the rocker arms if the valve lash isn't adjusted to spec.
Old Mar 20, 2005 | 03:14 PM
crazy4396063
honda
should i be able to hear any noise how do i know whats normal?
Old Mar 22, 2005 | 01:49 PM
civicandtegra's Avatar
civicandtegra
crazy im thinkin of the same motor for my 91ls cuz that motor has 200k and is about to die what u pay and where u get it from
thnks in advance
Old Mar 22, 2005 | 02:52 PM
ED9man's Avatar
ED9man
driver
Mine is a lot noisier, sounds a lot better too, like a motorcycle almost. The SOHC was wheezy at best.
Old Mar 22, 2005 | 04:22 PM
crazy4396063
honda
i got it from jdm depot in new jersey ......i pulled the head off and the internals look brand new not a spec of carbon on the thing.....im thinking it has 5-25 k on it but im going to check the valves in case they needed to be adjusted
Old Mar 25, 2005 | 11:34 AM
slvrteg's Avatar
slvrteg
big boys toys
Could also be the fuel injectors, my B18C sounds similiar and I was told it was probably the injectors. which is apperantly normal, B18C are known for having noisy injectors. hopes this helps.
