Engine question?
Old Feb 25, 2005 | 12:44 PM
ED9man's Avatar
ED9man
driver
Default Engine question?
What could cause an engine to loose top end power? Mine doesn't feel as quick as it used to top end.
Old Feb 25, 2005 | 12:45 PM
teg92's Avatar
teg92
WHAT OK YEAH!
did you beat on it alot?
Old Feb 25, 2005 | 12:46 PM
ED9man's Avatar
ED9man
driver
I guess. The thing is made to do that though. What could be worn out or gone bad?
Old Feb 25, 2005 | 12:50 PM
teg92's Avatar
teg92
WHAT OK YEAH!
maybe you might want to think of redoing the head such as valves, reatainers, springs, cams etc..
Old Feb 25, 2005 | 12:54 PM
sherwood's Avatar
sherwood
I missed Sean
yeh, get everything rechecked and tightened, at those high engine revs something might just be a little out of whack causing you to lose power, that and maybe you're used to it by now and are ready to up your engine to a b18
Old Feb 25, 2005 | 12:57 PM
ED9man's Avatar
ED9man
driver
Anyone actually know anything specific that tends to go bad with my application?
Old Feb 25, 2005 | 04:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would check the compression. Maybe there is a loss of compression due to ring wear. There could also be a large buildup of carbon on the pistons and combustion chamber that cause a loss of power. Another thing you could think about is if your fuel maps need to be adjusted to make power at high RPMs due to the wear of the engine.
Old Feb 26, 2005 | 06:43 AM
ED9man's Avatar
ED9man
driver
thanks! I noticed another issue today. I would take it up hard in first and second and when I shifted into 4th off the gas going like 50 it would make a kind of loud tick sound once or twice while engine braking. It has never done this before. What could it be?
Old Feb 26, 2005 | 08:00 PM
ED9man's Avatar
ED9man
driver
Also what are considered good compression and leakdown specs if I do test it?
Old Feb 26, 2005 | 10:55 PM
Provocateur
On permanent hiatus
What is the compression ratio? I don't know much about that engine, so I couldn't tell you without know the compression ratio you are running.
