Engine question?
Old Feb 27, 2005 | 05:00 AM
ED9man's Avatar
ED9man
driver
Old Feb 27, 2005 | 01:31 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
My GSR new would have compression of about 270psi at 10:1 compression ratio, so I would imagine the 10.2:1 ratio would peak at around 290psi. The minimum you would want to see is around 200psi. Also, you don't want to see a 30psi variation in any of the cylinders.
Old Feb 27, 2005 | 03:10 PM
Civic2Scooby's Avatar
Civic2Scooby
actually the minimum factory allowance is 180psi with no more than 20psi deviation between cylinders, and no lower than 180 if there is a deviation.....at least according to ALLdata
Old Feb 27, 2005 | 11:20 PM
Provocateur
On permanent hiatus
OK. I was just making an educated guess considering I only have the specs for my GSR sitting in front of me. I was relatively close though.
Old Feb 28, 2005 | 12:50 AM
Civic2Scooby
wasnt tryin to put you down mang..sorry if I came off prickish...I just happened to be on alldata when I read this.
