B18C1 what ECU?
Old Feb 13, 2005 | 11:49 PM
loodboi's Avatar
loodboi
هونده بريلود
Default B18C1 what ECU?
What ECU does the C1 have from factory?
Does P30 work fine?
Old Feb 14, 2005 | 07:52 AM
b16ahybrid's Avatar
b16ahybrid
The p72 is the factory obd-1 b18c1 ecu
The p30 is for the del sol vtec(b16a3), The b16a doesn't have secondarys like the b18c.The p30 won't operate the secondarys.
I'm running a p72 on my b16a and I noticed that my car ran on the rich side before I went with hondata. I believe the fuel maps are a little different.
Old Feb 15, 2005 | 07:40 AM
qtiger's Avatar
qtiger
b18c1 cams have longer durations and the b18c1 has the dual stage manifold, hence the fuel map differences.
Old Feb 16, 2005 | 02:54 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Also, you have to be careful when buying because there are OBD1 and OBD2 P72 ecus.
-PHiZ
