Urgent! Need help with swap!
Old Feb 28, 2005 | 11:51 AM
refri3dnoodle's Avatar
refri3dnoodle
Default Urgent! Need help with swap!
I have a wierd situation on my hand.I have a B20B engine with a B16 Head and B18 Transmission and I have modidfied everything for ODB2 and I am using a B16 ecu. I am swapping this into a Civic coupe (originaly a D16). I have gotten the engine in okay. The car turns on but the biggest problem I'm having right now is that I can't get it to stay on unless I set the idle speed to 1200rpm. Once it stays on, the other problem I have is when it gets to operating temperature, it begins to backfire out the intake and exhaust and then turns off. I am using the fuel injectors from the D16, and pretty much everything else is from the B16. Any ideas why the car can't stay on and keeps backfiring? I've been working on this for 5 days now and still can't figure it out. Thanks inadvanced for any help.
Old Feb 28, 2005 | 12:00 PM
Snoopy's Avatar
Snoopy
been there done that
what ecu are you using?
Old Feb 28, 2005 | 12:02 PM
refri3dnoodle
B16 ECU (for civic SI)
Old Feb 28, 2005 | 12:04 PM
teg92's Avatar
teg92
WHAT OK YEAH!
is the timing set right? And what year is your car?
Old Feb 28, 2005 | 12:13 PM
refri3dnoodle
The car is a 2000 model. I've checked the timing, valve clearance...still can't figure it out...
Old Feb 28, 2005 | 12:29 PM
teg92's Avatar
teg92
WHAT OK YEAH!
did you change some wiring around? Heres a web site that tells you what you have to re-wire. Since you car is a 2000 its going to be OBD2b
http://technet.ff-squad.com/
Old Feb 28, 2005 | 12:30 PM
teg92's Avatar
teg92
WHAT OK YEAH!
oh ya its under
ECU & Wiring Tech
OBD-2b ecu pinout diagram (rev.3)
Old Feb 28, 2005 | 12:35 PM
refri3dnoodle
I haven't changed anything...thanks for the link
Old Feb 28, 2005 | 12:41 PM
teg92's Avatar
teg92
WHAT OK YEAH!
you need to change those wires and Im sure your car will run Good. Did it to my civic and ran good
Good luck
Old Feb 28, 2005 | 02:06 PM
refri3dnoodle
thanks alot for the help...we're gonna change the wires today
