I just realized that since I have a OBD2b ECU that the wiring should be ok...Any other ideas? Could it be that the D16 duel injectors aren't working properly with the B16 ECU?
you still have to change the wiring even if you have the right ECU. I had the Right ECU for my swap and i still had to change the wiring around
well since tha car is a 2000 ex 5spd i didnt have to change tha pinouts but i did find out that i have a short in tha harness some where so now ima get a 2000 si harness get a obd2b to obd1 jumpharness and run a p28 ecu. tell me what u guys think. oh by tha way my problem was in tha distributor
